• Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' the posts that you read.
Hydraulic setup on bellhousing
Ramcharger90
Well-known member
1,043
N/A na
306, Bcam,
Rock Auto 5% Discount Code: 80CBDBD15DC160 Expires: January 4th, 2021
svtcards
Active member
41
Lyman maine
3'' front 4''back
Who makes those brackets?is it a kit or pieced together?
Ramcharger90
Well-known member
1,043
N/A na
306, Bcam,
You can get one from modern driveline I think it is. But most are home made
svtcards
Active member
41
Lyman maine
3'' front 4''back
Ramcharger90
Well-known member
1,043
N/A na
306, Bcam,
U saw external slaves bolted to bellhousing break.im curious how that could possibly happen.it doesn't move.its probably someone's home made hack job that they thought they knew what they were doing and found out the hard way.i ll let u know how mine works.hoping to have engine with trans in truck next mth
I had the first slave cylinder made by centric go bad in a month. It was leaking from inside the barrel, it had no scratches or scoreing in the barrel. I replaced it with one from a different company and it has been working fine since. But it messed up second in my new T5Z so high rpm down shifts grind a little.
svtcards
Active member
41
Lyman maine
3'' front 4''back
Slave cylinder or clutch master u mean?
Junglejoe
Active member
28
Columbia Missouri
6.0
Bump for a little more info.. fixing to tackle the hydraulics.. .what are you guys doing as far as bleeding the system.. (I'm using the f550 and 280z slave)
bench bleeding it befor it even goes on the truck, if so..anyone done that and whats the procedure?
smilinjack
6
rochester, mi
ford ranger
351C
2"
TBD
Always bite off more than you can chew!! :)
Don't know if this applies to anyones specific needs , my application was for a Cleveland swap into a 95 with a hydraulic external slave. I bought a Novak slave after logging on to their site and viewing their applications, albeit not for my particular build. I believe it was a Ford or Jeep application that had a bracket plate bolted to the existing bellhousing bolts that gave me inspiration to make my own plate. I designed it to work with my toploader trans. I wasn't convinced about the durability of a ' pull type ' slave so I went searching for different ideas. I am using the F550 Master Cylinder to get the increased bore size to function properly with the 3/4" bore slave cyl. The mounting bracket for the master needs to be altered slightly to fit the larger ( but typical ) F550 m/c.
The fittings needed for this conversion are available at the parts depots. Hope this helps
Junglejoe
Active member
28
Columbia Missouri
6.0
I went ahead and drilled.my bellhousing. I didn't want to.. but we'll see how it works
smilinjack
6
rochester, mi
ford ranger
351C
2"
TBD
