Hydraulic clutch line
Rowanoak88
Burlington, WA
SUPER FRUSTRATED!!! WHY IN THE WORLD WON'T THE HYDRAULIC CLUTCH LINE ATTACH TO THE SLAVE??? EVERYTHING IS CLEAN AND BRAND NEW BUT THE DAG GUM LINE WILL NOT ABSOLUTELY WILL NOT CONNECT. I CAN FEEL IT ENGAGE BUT IT WON'T STAY PUT!!! I CRACKED THE BLEEDER BENT OUT THE PRONGS EVERYTHING!!! I HAVE BEEN WITHOUT MY TRUCK DUE TO THIS B.S. AUTO TO MANUAL TRANNY SWAP SO SOMEONE PLEASE HELP ME!!!
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
Need more info on what you are installing. Some clutch lines are different sizes than others. Tell us what you have. You can fix this.
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
If you are putting a manual in place of an automatic what vehicle did the trans come from ? What master cylinder did you get verses what slave cylinder you got ?
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
I put a 93 explorer 4.0 manual trans in my 89 Bronco II 2.9. Used the explorer flywheel and clutch assembly and the hydronic line from the explorer on my BII master cylinder. The lines were different sizes and the BII would not fit on the explorer slave.
Rowanoak88
Burlington, WA
Sorry. I was frustrated. 1993 ford ranger xlt. 4.0l ohv. I put a m5od manual in it.
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
What vehicle did the m5od originate? What Year model did you buy master/ slave for?
Rowanoak88
Burlington, WA
M5od from a 95 4.0l ohv. The slave, fly, and clutch kit are all for 93 ranger. Bolted right up to my engine and right up to my tranny. Everything slid right together. So i went and got the hydraulic line for a 93 ranger 4.0l ohv and had trouble getting it in. It was like it wasn't for my truck cuz of the permanent bends in the line. But i made it work and now it just won't go into the slave.
Rowanoak88
Burlington, WA
My fly, clutch kit, slave all came from internet and all fits and bolts up. The hydraulic line came from autozone. All brand new.
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
So my slave went out last winter. The new one had a different connection than the prior one. It included a new bushing for the hydronic line to allow it to connect to the new style slave connection. If you have the new style slave it need the new bushing as mine did.
BTW. You should not need the little fork tool to connect the line. Only to remove it.
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
When you try to connect the hydraulic line are you trying to use the fork tool? If you do it will not stay connected. You should only have to slide the line with its bushing into the slave. The fork is included with the kit so you can remove the old before installing the new.
Rowanoak88
Burlington, WA
I actually bought the flywheel, clutch kit, slave, was all for 93-96 it wasn't year specific other than that.
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
When you use the pronged tool to put the line on you are pushing the bushing in which releases the line from the slave. Try just pushing the line in bare handed. 💪
Ramcharger90
1,708
N/A na
306, Bcam,
Get a prybar pull back on the throw out bearing and crack the bleeder. Then close it after some fluid drains. Dont slip off it with the bleeder open it will suck air in. But it should just snap together after this.
Rowanoak88
Burlington, WA
As I said, I purchased everything brand new and have yet to be able to successfully attach the hydraulic clutch line. As such there is zero fluid in anything. And the bleeder is open. So open bleeder and dry slave so no fluid to release.
Rowanoak88
Burlington, WA
Only been using my hands for the most part
