Hub swap from donor truck
Uncle Gump
Token Old Guy
11,876
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
That topic is in the tech library
Couple nice trucks you got there.
scotts90ranger
3,666
Dayton Oregon
2.3 Turbo
The "conversion kit" is just the two lock nuts and washer, yes you can just swap the parts across no problem
dvdswan
2,518
Seattle, WA
Ranger XLT 2WD
Welcome to the site.
Northidahotrailblazer
302
Northern Idaho
Solid Axle Swap 4x4
8 inches
37"
Aren't D28 hubs smaller than D35 and don't cross? Unless the 86 has a D35 in it, which someone would of had to swap, they won't work on your D35 that is in your 92 ranger.
Uncle Gump
Token Old Guy
11,876
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
The Tech Library is assembled by category but it's a beast of information.
We do also try to move information around in the forums in an attempt to keep topic organized. It's a bit of a challenge. All we can do is try.
When you can't search it... ask it. Someone is pretty much always there to help.
scotts90ranger
3,666
Dayton Oregon
2.3 Turbo
Crap, somehow I missed the '86 part of the question last night... that's a Dana 28 and the hubs and lock nuts will NOT fit on the Dana 35 on the '92
scotts90ranger
3,666
Dayton Oregon
2.3 Turbo
Ok, yeah, if junkyarding all you have to do is grab the hubs and take off the locknuts, I have a couple extra sets for "just in case" purposes hanging around somewhere but all my junk is strewn about all over...
