DangerKnödle
- Jun 26, 2021
- 3
- South Carolina
- Ford Ranger XLT
- Engine Type
- 2.3 (4 Cylinder)
- 2WD / 4WD
- 2WD
Hey!
I have a 96 2.3L 2WD Ford Ranger with stock doe track 14s that I have recently put on 15in steel wheels with new tires. After having it re-weighted, the truck still has a small shimmy. The 15in wheel itself fits tight on the wheel stud and doesn’t have any play, but there is atleast a 10mm gap between the wheel hub and the center hub itself. I have ordered hub centric rings that are 83.3 to 70.3 (measurement of the OD to ID). Also, I know it may need an alignment but the bearings and bushings are good. Do you think the rings will solve the shake? Thank you!
Pictures attached for reference.
