How snug is PCV valve fit supposed to be ?
Burnsy
72
Hudson fl
Ford ranger
Mine isn't snug, airtight. Is it supposed to be ?....I can freely move it. It stays in the hole....
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
Engin?
Trans?
4WD+1354 TCase or 2WD wOut TCase?
If V6~4.0L~SOHC Engin & 5r55e Trans,
PCVValve is at rear end of left ValveCover next to FireWall, 1/4Turn Insert\Removal.
Plastic tabs in ValveCover commonly break if PCVValve is not inserted\removed properly.
Cure is a new ValveCover; can try temporary HeatShrinkTubing around PCVValve to make it fit snug in broken hole.
PS: edit your signature with basic vehicle specs: Year+Model+Engin+Trans+TCase+Diffs+..
makes asking+answering questions easier+quicker.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
It's got to be tight enough to prevent a vacuum leak. Sounds like you need a new grommet.
DILLARD000
652
Earth
2001 Ford
SportTracJob2
V6~4.0L~SOHC
V6-4.0L-SOHC PCVValve hole has no grommet, it fits directly in 1/4Turn hole in plastic ValveCover. Traditional PCVValve & Grommet might work. Need to check hole diameter.
