how does the duratech compare to the old 2.3?
racsan
5,592
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
im considering a newer ranger, a '05 with a duratech, while ive had 3 of the older 2.3 sohc engines, ive never driven the newer '01 series with the dohc. ive read where its more hp, at about 1,000 more rpm. how does the newer series compare in the real world? i plan on doing a test drive soon but i know i wont be able to test towing a trailer or any hilly conditions.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
TRS 25th Anniversary
6,141
woodhaven mi
FORD mostly
BIGGER
sawzall?
the old lima 2.3 with a lower boost turbo build is really awesome.
the duratech with mid turbo is superb.
the duratech once studied and dealt with I see as far more cost effective....and at this point easier to find with lower miles. the eco boost is based within it.
well proven....go row through the gears of a speed 3.
mavereq
Concrete, WA
I’d love to build a duratec. They’re way lighter and the heads breath well. Esslinger does some nice work on them, but it’s spendy.
3,636
The two biggest drawbacks I see to the Duratec over the Lima are that you actually need tools to time the engine, and the crank is not keyed.
The fact that you need tools to time it is mitigated by the facts that 1) the tool set is like $30, and 2) it's a timing chain, so you really shouldn't ever have to dick with the timing.
The non-keyed crank drives me up a wall, especially on an interference engine, but I have never seen one slip time, so... And since they were in everything, Rangers, Focuses, Fusions, even Edges, Explorers, and Mustangs by the time you take into account the 2.0, 2.3, GDI and the GTDI versions I have probably worked on a few thousand of them.
3,636
I'd love to just shove a turbo one into something. Once you get the engine control stuff worked out it should be almost plug and play. All the high pressure fuel stuff is within 6 inches of the engine, and the HP pump is mechanical, driven by the cam.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
706
Central Indiana
IMO, the Duratec is the most modern engine Ford chose to put into a Ranger. It's lighter, more powerful, more fuel efficient, and has much lower emissions than the older Lima 2.3L. The basic architecture is still being used in Fords rolling off the assembly line.
racsan
5,592
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
That’s good to know, not a fan of the newer stuff but the older stuff is getting hard to find. Odd that there’s no key way in the crank, I figured it would be a interference engine, it’s probly really similar to my moms Mazda 3 engine, I was deep into it 3 or 4 years ago when she drove through high water and hyrolicked the motor, breaking rod #1, busting the oil pump off the bottom of the block, punched parts through the oil pan. All with less than 10K miles on the car. Was nice to work on something that new and clean. Don’t know why it wasn’t turned in to insurance. The ranger I’m looking at is a 05, has under 18K miles and they are asking $9K for it. Hope to test drive it today.
3,636
Oh dude, if you have been in a Mazda 3 you are good to go. It's not similar, it's the exact same thing.
The biggest difference between the 2.0/2.3 in the Mazdas and the 2.0/2.3 in the Fords is where the AC compressor got mounted.
work2do
27
Columbus, Oh
2.5
All due respect to all comments (adsm08...thanks !)
I have had long term success with both engines. Late 80's to present with the Lima. Working on a turbo swap to a 1990 mustang. Have a high milage duratec (200k) in an 05 Mazda Tribute. Mrs. Is driving a 2017 Escape, 2.5 . Just bought a 2010 ranger, 4 banger auto.
Sold my 99 & 01 Lima trucks at 300k, 220k. Timing belts ever 100k. A friend at work went to 700k on a duratec (look up 706,000 ranger). Great motors, yet I like a timing chain that holds up well, as opposed to changing belts. Own 3 of each motors.
Truck of The Year
Kirby N.
2024 Truck of The Year!
Vagabond Video
