How did you mount your rock sliders?
cmequestionu
17
Federal Heights, Colorado
Solid Axle Swap 4x4
~10
I've been hunting around for ideas for rock sliders and have found some of you guys have some pretty good looking ones but the thing I don't see a lot of is how you mounted them to your frame. I know some of you decided to weld and some decided to bolt. What I'm interested in is where you chose, how/why, and (most importantly) pictures!
Wallows in rivers
22,004
SW Iowa
Bolted to spread the load out on the frame and so they are removable if I ever feel the need to remove them.
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
15,697
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I don't have any yet but the best way with the Ranger frame being C-Channel, is welded on to the frame. The second best is bolted to the frame. Either method should be strong enough not to flex and hit the body of the vehicle. Basically, if you can't use a jack to lift the vehicle off of any given point on the slider, it isn't strong enough.
Another option offered by Affordable Off Road, is metal sections that replace the door sill of the cab. Those are welded in and offer better ground clearance than a bar mounted under the cab.
cmequestionu
17
Solid Axle Swap 4x4
~10
Did you drill new holes or did you go based off holes that were already there? How did you decide to mount the plates where you did?
cmequestionu
17
Solid Axle Swap 4x4
~10
I've looked into the ones from Affordable Off Road but the impression I get is this option is better for unibody construction as it stiffens the whole truck where as body on frame would transfer that force through the body mounts.
Uncle Gump
Boomers gotta Boom
16,015
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I moved this to the bumper/slider/cage forum just to keep things tidy.
I'm looking to do sliders myself... haven't settled in on which ones... might even just make my own. I'm going to have to get busy and figure it out.
Curious Hound
Formerly EricBphoto
20,167
Wellford, SC
6"
I bolted mine. Complete custom design. So I chose my mounting points and drilled my own holes.
Wallows in rivers
22,004
SW Iowa
Drilled holes, just kinda put them as evenly placed as I could without interfering with anything. I made backing plates to go on the backside as well.
Mine were a trailgear kit iirc originally intended for a 80's Toyota pickup.
cmequestionu
17
Solid Axle Swap 4x4
~10
Sorry, I was looking for ideas for these trucks specifically so as not to get confused with newer rangers or other RBVs. Hopefully we'll both find the answers provided enlightening.
SenorNoob
1,595
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Seriously considering this myself. Will probably just be a square tube running wheel arch to wheel arch bolted to the frame. I hadn't considered backing plates before. That's a good idea. The frame is pretty thin.
Junk Collector
Truck of Month
5,931
Rapid City SD
I did the ones on my Explorer the same way that @85_Ranger4x4 did his. Same sliders too, those trail gear ones are legit.
On my 86 I cut the rockers out and replaced them with 2x4” steel tubing, 1/8” wall and then added another 3/16 plate on the bottom.
Truck of The Year
Kirby N.
2024 Truck of The Year!
Vagabond Video
