- Sep 6, 2018
- 55
- minnesota
- Ranger
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 4WD
- My credo
- If youre gonna be dumb you gotta be tough
Not sure the directions I want to go with my low mileage 94 4.0 ohv. Don't say v8 swap nows not the time for me. First idea is
95mt heads
66mm bbk throttle
422 comp cam
Headers
94 motor + 95mt head would put me around 10.25:1. So thinner head gasket for 10.5:1 compression.
2nd idea
Rebuild heads
M90
Injectors
422 cam
Headers
Use the stock low compression to my favorite
And run 5psi.
Fabrication is no issue for me but tuning ob1 isn't the best I've heard. This was a good running motor when pulled out of a winter beater. Rust killed the frame at 74k. It will get pulled down to a short block so I can inspect the pistons and crank bearings.
95mt heads
66mm bbk throttle
422 comp cam
Headers
2nd idea
Rebuild heads
M90
Injectors
422 cam
Headers
And run 5psi.
