Hood stuck shut
borked
Spokane
Ranger supercab
Howdy yall.
I must have jammed the hood shutting it.
What do yall do to open it?
Pulling the cable does nothing, just a little give and nothing.
Can I remove the latch or something through the grill or from underneath?
Thanks
Ranger850
Doesn't get Sarcasm . . .
4,658
Tallahassee Florida
Stock 2"
Stock
Yes. You have to reach up with something, behind the grill and all the way up to the latch, and pull the cable. My hood latch cable broke several years ago, at around the battery. I just dropped the front section , of the cable, down to where I can grab it, behind the bumper. Tied a little kids toy to it to keep it from flopping around. Now i just reach under the bumper and pull the cable down to open my hood.
Eddo Rogue
2,472
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
have a buddy pushing down on the hood as u pull the cable, if it works, lube everything before closing it again.
ericbphoto
Overlander in development
16,340
Wellford, SC
6"
Plus, if that works, you may need to lower the bump stops at the front corners of your hood. They might be putting too much pressure on the hood.
borked
Spokane
Ranger supercab
I appreciate the responses.
I jammed it real good. No wiggle room to push down and I can pull on the cable until I feel like its about to break.
Switching gears.
What I really need to do is reset my battery. I was working on my ignition interrupt when I jammed the hood shut.
Any ideas on that with the hood being stuck closed?
Then I can drive it to my buddies or a shop if need be.
alwaysFlOoReD
5,029
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
If worse case, a 1/4" ratchet, extension, and maybe a universal joint to remove the latch from the rad support.
Alan_nc
140
US
Ranger Splash
You realize your post has us all going out and lubing our latches real good so we don't end up with the same problem.
ericbphoto
16,340
Wellford, SC
6"
'Scuse me. Gotta go do something in the garage real quick.
sgtsandman
Aircraft Fuel Tank Diver
12,382
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I lube mine with white lithium grease every spring and fall. Over kill? Probably. But I’ve never had a hood unlatching issue either.
gw33gp
527
Costa Mesa, CA
4.0 SOHC
33"
It doesn't sound like your problem, but I had this happen to me while in the wilderness for a couple weeks. I could pull on the hood release and nothing would happen. After working with it a little I realized the bump stops had worked their way down. When I pulled the cable the hood had no tension to pop up to release. I asked someone to push up on my hood while I pull the hood release and it came up. I then adjusted the bump stops up and the hood release worked normally again.
Fast Eddie
2,654
On The Road
Ranger Edge
2x4 on 4x4 Factory Chassis
Mine was the spring. Found a replacement at Ace, of all places.
rusty ol ranger
Im a Jeep guy now.
7,271
Michigan
177 CID
You tripped the main latch and shut it and now the secondary(hand latch) is holding it.
I did this once on my F250....its a royal bitch, removing the latch assy from the core support is the only option.
borked
Spokane
Ranger supercab
you are exactly correct this is what happened
Kirby N.
March Truck of The Month
