idlewyld89
- May 29, 2011
- Reaction score
- 0
- Make / Model
- Ford
- Manual
Hey everyone, happens to be my first post!
I just recently bought a used Ranger (2003 2.3L 4cyl) and it just developed a small RPM issue. I'll do my best to be verbose:
When I start the engine, the RPMs are very slow to settle down. Starts out at about 2k and works its way down to ~800 over the course of about a minute. This isn't too abnormal and isn't the real issue.
When I hit the gas, still in neutral (or even in gear, for that matter), the RPMs obviously go up. However, they hang around 1500 for just a second or two, before dropping back to the regular ~800/900.
What I have done so far:
I disassembled the throttle body and cleaned it out. Note that I did not replace any of the gaskets for the TB, I simply took a drop of olive oil and ran it over the existing gasket to "reseal" it. Took a look at the TPS, dosen't look overtly damaged, and the fact that the truck accelerates alright tells me that it is likely not my main issue, if at all. I took off and looked at my IAC valve, and it looked a bit dirty, but I was told over at the local parts store it is highly likely not to be the problem, as the car does not stall. I did not clean the valve.
Also, when I hit the throttle from within the engine compartment, there is a hissing sound apparently coming from the throttle body/manifold cover area. Just off sound alone, it appears that is where it's coming from, however I cannot locate any leak with plain soapy water.
I'm thinking it must be a vacuum leak, but I just cant find it???
Now, mind you, the issue did improve after I removed and cleaned the throttle body. Before, it was revving up to 2k RPM before dropping back down to the normal ~800/900 RPM. Not sure if that was coincidence or if the cleaning actually helped that much.
This truck has been my first foray with auto mechanics. I've generally got a knack for this sort of thing, but when you don't know the nature of what you're working on (i.e. the rules of the game) its a bit harder to play.
Anyways, suggestions are obviously welcome. Would appreciate any past experiences with similar issues.
Thanks,
Idlewyld89
PS: Figured it was fitting that my user name reflect my first issue with my truck... hopefully that doesn't turn out to be horrible luck
Thanks,
Idlewyld89
