High mileage Ranger - Worth investing in?
srisitt
8
Washington
I recently bought my first truck, a 91 4.0L Ranger that I was told had 157k on it but turned out actually has 257k. Now I'm trying to figure out if the truck is still worth investing time and money into.
A little about the truck:
- It has the original engine and transmission, never rebuilt.
- It had one owner from 1991-2019. The owner seemed to know the truck very well and took good care of it.
- Seems to run well, I've taken it on the freeway and around town without any issues. The only things I've noticed about the engine/transmission are a lifter tick that goes away when it warms up and a slight, almost unnoticeable grinding in low RPM's in 3rd gear. Otherwise it runs great.
I figure what I should do now is see what kind of shape the engine is in. I'll start with checking the compression, is there anything else you guys would recommend I look at? Would the ECM in a 91 be able to give useful information about the engine if it isn't misfiring etc.? Is it even worth touching a Ranger with this many miles on it?
Thanks for any and all help. Learning as I go. :icon_confused:
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
If its a manual trans, runs good, and was well cared for 257k wouldn't phase me at all.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I see what you did there...
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Honestly, mine was one of the ones that was anyone's guess to miles when I bought it. Turned out it had 262k on it, not 162k, but PO's daughter was honest and told me she wasn't sure.
4.0 is easy to work on, and parts are cheap. If it's a 2wd manual trans with the M5OD, the trans is even easier to work on. Slap a shifter rebuild kit in it ($23 on rock auto), and just freakin' drive it lol.
Mine has rust issues. Yours looks really clean, but I could be wrong. Depends on how you define "worth it," but a ranger of that era is fun to drive, cheap and easy to work on, and worse case will teach you how to be a better mechanic. I say go for it, but that's me.
If you get bored with it, this is an option.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Also, nor really for the ECU. Should be an EEC-IV, but I could be wrong. Either way, it's OBD1, and not terribly advanced, but can give a LOT of useful data if you ask questions on the V6 forums.
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
645
Central Indiana
What were your plans for the truck when you thought it had 187k?
srisitt
8
Washington
Well I suppose at 157k, with a single owner and good maintenance I figured I’d have tens of thousands of miles on the original engine/transmission before needing a rebuild. At 257k I’m amazed it’s gone this long without needing any major work. I want to be able to take it long distances so I’m a little anxious about getting stranded if don’t at least get the top end rebuilt.
Ranger850
Doesn't get Sarcasm . . .
4,686
Tallahassee Florida
Stock 2"
Stock
A one owner, well taken care of truck, that runs fine, and you want to tear it down and rebuild it. I understand not wanting to be stranded, but where I come from, If it ain't broke, don't fix it. How do you know the PO never had anything done to the top end? that may be why it is running so good. IDK how much info you have, but it sounds like he took good care of it, and probably had it serviced and repaired regularly.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Carry a back up set of sensors, fluids, basic electrical repair items, a meter, and hand tools. Circumnavigate the globe. It's a Ranger. You'll be fine.
Denisefwd93
74
South East PA
It's elementary at this point you already bought the truck and you own, it call it buyer's remorse.
Are you sure it's 257? because that has a 5-digit odometer doesn't it? I've never quite understood the logic for them, I had one in my 93 & my94 has an od like that,
ericbphoto
Overlander in development
16,541
Wellford, SC
6"
Years ago, it was a miracle for most vehicles to make 100k miles. Now, it's more common. Better design, better lubricants, whatever. Used to be that only the premium vehicles with the best maintenance got to the 6 digits on the odometer. Now, just check it out good and maintain and repair it best you can and you should have a good time with it.
Junk Collector
Truck of Month
4,789
Rapid City SD
257k would not bother me. Just about anything on them is easy to fix and relatively cheap especially if you can do it yourself and I'm guessing the body is probably in pretty good shape given your location.
Honestly I'd rather have a 1991 with 257k on it than one of that year with 57k... I've had a bunch of old, low mileage vehicles that were just total shit piles. Looked nice but sitting unused is hard on vehicles. If it's rolled through that many miles, chances are it was maintained pretty well.
ericbphoto
16,541
Wellford, SC
6"
I agree. Machinery likes to be used and maintained. Sitting idle for long periods is the worst thing for almost any machine. On the submarine I was on, the nuclear reactor and propulsion equipment would run great While it was operating. But shut it down and start it up frequently and stuff started to fail. That thing loved to run.
