xentris02
- Oct 30, 2009
- 0
- st.louis, mo
- ford
- Engine Size
- 4.0 v6
my truck has an idle problem once in a while when i come to a complete stop the truck idles higher than normal making it hard to stop it will idle around 600 normaly. but when i stop and the idle problem show it will idle around 900 and when i throw it into park it will jump to 1000 to 1500. i do have code but my first question is when i did the koeo it threw out code 111 (system is ok) but then it threw out more codes? is it suspose to do that because in my mind system is not ok if its throwing out codes. keep in mind its obd1
codes i got during KOEO
111 System checks OK
122 (O,M) TP low (possibly grounded or open circuit) - TPS
125 (M) TP voltage was lower than expected - Fuel control
then on KOER test i got
116 (O,R) Engine Coolant (ECT) sensor out of range - ECT
538 (R) System did not receive "goose" test - TESTS
536 (O,R,M) Brake On Off open or shorted to ground - BOO
if you all can please help me figure out these problems thanks ahead of time.
