JohnG
- Jun 7, 2020
- Reaction score
- 39
- Location
- Knoxville TN
- Make / Model
- Ford Ranger STX
- Engine Type
- 2.9 V6
- Automatic
- 2WD / 4WD
- 4WD
- Tire Size
- 235/75R15
- My credo
- We need to stop messing with the framework that the founding fathers created.
Gang, new problem this morning. High idle will not drop to normal after warm. Stays at about 2000 rpm.
Pulled codes and got code 32. EGR not responding.
Disconnected the IAC valve and had no change.
What I did the night before… Looked at the air filter. Sprayed some soapy water on the pass side valve cover to look for an oil leak and a possible leaking injector.
Ideas for where to start troubleshooting?
(I tried searching but “code 32” brings few results as it won’t find two letter searches)
Thanks!
Thanks!
