Hickup when full throttle/or lugging?
NV firefighter
Firefighter
Fallon, Nevada
275/70x16
Hey guys and gals, I have a little bit of a hickup when under a load or when using full throttle in 5th....kind of stutters for a 1/2 second. Any ideas?
Also, my tach doesn't work correctly most of the time...is there a pick up I could clean up or something?
Thank you for the help...love the site!
franklin2
1,758
Virginia
Bronco II
How long has it been since the sparkplugs have been changed? On the tach problem I am seeing there have been problems with the circuit board and connections in the cluster on these trucks.
rusty ol ranger
2.9 Mafia-Don
7,489
Michigan
177 CID
I think the tach is wired into the coil. @RonD is that correct?
What im getting at is the two issues maybe related....
NV firefighter
Firefighter
Fallon, Nevada
275/70x16
I'm unsure. I just purchased the truck from my neighbor, and it has been sitting for a bit, year maybe. It doesn't seem like a misfire to me...more like a total cut off. It happens so quick.
But that seems like a cheap fix so I'll try that first! Thank you
8,370
When there is a distributor and single coil then yes, the tach signal comes from "-" terminal on the coil
In distributorless systems it comes from crank sensor via spark module or computer
NV firefighter
Firefighter
Fallon, Nevada
275/70x16
Thank you
