- Mar 31, 2019
- Reaction score
- 803
- Location
- FL
- Make / Model
- Ford Ranger
- Engine Type
- 4.0 V6
- Engine Size
- 4.0 SOHC S/C
- Automatic
- 2WD / 4WD
- 4WD
- Total Lift
- 0
- Total Drop
- 0
- Tire Size
- Just the right size to touch the ground.
Just how accurate do you need the cam timing? Today's milling machines aren't accurate enough? I don't buy that as the reason for even a second. It was done because some young engineer thought he had a better idea and the bean counters bought it because it was going to get them more service work and/or require non- dealer shops to buy more unnecessary tooling. It's a STUPID system and was a solution without a problem. If you can build a tool set that holds the crank and cams in "perfect" position, you can cut a keyway just as accurately.Removing the keyways wasn't done to reduce manufacturing cost, it was done to enable more exact cam timing-pin everything in place and torque it up- AS LONG AS IT HOLDS, the timing is spot on, not within tolerances. Cars are more complicated than ever but they last longer than ever before.
