some pics
First starting, dirty dirty truck
Had to chip away this cardboard underneath the floor mats. It was falling apart.
after the first coat
second coat
overall it went good. Its all about the prep work. I vaccummed then wiped everything down with a wet cloth to get most of the dirt out. Then after using the abrasion pad I vaccummed again, then wiped everything down with acetone. Let that dry then go to town. I layed it on pretty thick cause i knew I wouldnt be using it all. I still have about 1/2 to a 1/3 left so Ill figure out something to do with it. I noticed water is leaking into the cab somewhere so when it cures up im going to drill a drain hole or two where the puddles are. Ill update later on how its holding up.
