Help
Swampdonkey87
Ok I have a 95 ranger 2.3 5 speed and it has developed a issue. At idle it has a slight miss to it but hardly noticeable but now it does this thing where when you start letting out on the clutch to take off it starts missing and popping for about 2 seconds then clears up and runs perfect till you shift and power down again. Has anyone had this issue before it does it hot or cold and worse with the a/c on. Don’t want to start throwing parts at it till I can narrow it down
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
maybe a vacuum leak?
Uncle Gump
Token Old Guy
13,454
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Describe the popping...
Is it like coughing back through the intake/
GT350HR
10
Anaheim CA
2.3
Nothing but Fords
I had a similar situation on my 2002 auto. It threw the engine check light as "lean" . Turned out to be that POS hose from the back of the throttle body to the PCV at the bottom of the intake. We only found it during a "smoke test" of the vacuum system . The elbow portion was "mushy" and high vacuum would cause it to suck air. Couldn't see it without the smoke pressurizing the system. Follow the smoke and there was the leak. All fixed now. About $10 to fix not including the smoke test.
Randy
