Help with transmission
Poweranger2
Georgia
Ford ranger
I have a 91 4x4 4.0 v6 ranger with a 5 speed and the transmission is no good and i cant find another one to put in the truck so could another 5 speed trans out a another ranger would work and what i would need to change
rusty ol ranger
2.9 Mafia-Don
8,646
Michigan
177 CID
You have to have a 4.0 trans. Or in theory a 2.8/2.9 trans but that would require work and youll be getting a weaker trans.
Any 5 speed from a 4.0 OHV will work.
3.0 and 4 cylinder trannys wont bolt up.
try www.car-part.com
NakedDucks
129
B’ham AL
God’s plan, not mine.
Ok…
So the 91 4.0 is an M5OD trans…
you can get another trans and swap the guts in, but the 4.0 was unique in that it has its own gear ratio set.
The 2.3 (single and dual cam), 2.5, 2.9, and 3.0 versions of the M5OD all shared the same ratio set, so, you’re not getting a weaker trans per say, just a ratio set that isn’t gonna be very well received behind your 4.0.
The 2.9 and 4.0 share that same bellhousing pattern, even though they don’t look the same and have different ratios.
I do, however, have 2 4.0 transmissions I’m not using… and I live in Alabama
So, I could always build you one…
PM me if you need…
rusty ol ranger
2.9 Mafia-Don
8,646
Michigan
177 CID
Ok…
The 2.3 (single and dual cam), 2.5, 2.9, and 3.0 versions of the M5OD all shared the same ratio set, so, you’re not getting a weaker trans per say, just a ratio set that is t gonna be very well received behind your 4.0.
PM me if you need…
When i said weaker i was reffering to a TK or mitsu trans.
NakedDucks
129
B’ham AL
rusty ol ranger
2.9 Mafia-Don
8,646
Michigan
177 CID
The TK and Mitsu were never behind the 4.0.
Yes I know they fit, but….
Which is why i said swapping to a 2.8 or 2.9 trans would be a downgrade
NakedDucks
129
B’ham AL
I know, and I wasn’t being a jack wagon, I was just trying to give him a fuller answer to his question.
You ever figure out if the 3.0 dipstick tube would fit? If not, I can get you one from a friend.
rusty ol ranger
2.9 Mafia-Don
8,646
Michigan
177 CID
No i havent had a chance to look into it. Im not sure how to even figure it out. Even if it would being a ford product im sure the part numbers are different lol.
Ill see what i can dig up and pm ya.
I wasnt tryin to be an ass either
NakedDucks
129
B’ham AL
rusty ol ranger
2.9 Mafia-Don
8,646
Michigan
177 CID
No offense taken. If you need a rough measurement, I can get you one in a few hours.
Ok....its not a huge deal.
I actually have one...but its on rusty #1 which is sunk to the rockers in the dirt from where its been parked for 15+ years. Im just trying to find one to save me the hassle of trying to get the damn thing out of the dirt
Rick W
October Truck of The Month
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
