- Feb 28, 2001
- 5,804
- Dayton Oregon
- Ford
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3 Turbo
- 2WD / 4WD
- 4WD
- Total Lift
- 6
- Tire Size
- 35"
Yes, bellhousing and I believe flywheel pattern is the same. The oil pan changed slightly in '86 like I mentioned, the seal moved from the block side with a big chunk of cork to the oil pan side and the front seal housing changed with it I'm pretty sure then there's the 2-4 bolts that are different sizes... I've bolted a newer aluminum oil pan on a '85 block just took some work...
Turbo engine differences are less than people think, it's just the oil drainback port on the passenger side then the turbo pistons, everything else is identical...
