Help with problems after rebuild
SplotchyAphid05
6
Minnesota
Ford ranger
Hello I finally got my ranger running again after pulling the engine and rebuilding it and running into problem after problem im hoping to finally be able to drive my truck again but the issue now is i dont want to leave it running long because of the horrid ticking its making and and i also think there was something starting to smoke on the passenger rear side of the engine bay but i did follow the valve lash guides on this site as well as i could but i will submit a video of it running for the experts here to help me out lol oh also the battery light stays on and it has a brand new battery and the alternator was good before pulling it all apart also the heads and engine block seem to get fairly hot after not running long at all like the radiator hoses were still cold
Link to hear the awful noise lol
Uncle Gump
Boomers gotta Boom
TRS 25th Anniversary
15,418
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I didn't look at the video...
What is your oil pressure?
gaz
761
Wa, Bremerton 98310
Ranger 5" (1½" Hiryder/3" body), BII 4" Procomp
Ranger 5sp, BII A4LD
Ranger 32"/4:10LS, BII 33"/3:73LS
@SplotchyAphid05
Oh... yes, you need to give setting the hydraulic lifter preload AGAIN! That may be all you did WRONG, the 2.9 doesn't get a lash adjustment, it requires a lifter preload setting.
On the heat side, it is possible to have installed the thermostat backwards. Also, even a brand new from.the package component can fail or malfunction.
MaicoDoug
473
Texas
Ranger FX4 LVL2
2 inches in the back, not enough in the front
32x11.5x15
Kapwing??? Youtube works better around here. Hope you can get her back going better than ever.
SplotchyAphid05
6
Minnesota
Ford ranger
Ill be able to give you an answer on friday or so i got the ole girl to start the day before we left on leave
SplotchyAphid05
6
Minnesota
Ford ranger
Thank you ill make sure to use youtube next time and me too I've been itching to drive her since I pulled the engine lol
SplotchyAphid05
6
Minnesota
Ford ranger
@SplotchyAphid05
So what I did was start at cylinder 1 on the compression strike TDC and loosened the the rockers until there was a reasonable gap then ran them down until they touched the spring then gave them 1.5 turns after that and repeated in that to all the cylinder in firing order is that the wrong method or could’ve I turned them to far or not enough and is there a way of knowing lol
Rick W
October Truck of The Month
Vagabond Video
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
