Help! Truck won't start, Theft Flashing
learfxr
I've been reading stuff all afternoon and not getting anywhere.
I drove the truck maybe a mile this morning and then parked at home. Went out later and now it won't start. Dash lights up and the Theft light flashes.
This truck is a backup and not driven often. Just replaced battery a couple weeks ago. Still shows good voltage with a meter.
Let the Theft light flash til it flashed the diag code. It seems to be a 1-1 code, didn't find any info for that.
I'm getting no clicks, or starter relay sounds.
I only have one working key, at least it used to work
It's a 2001 4cyl 5spd
Any help would be great
The dealer told me to tow it there and they Might get to it next week. This is my backup truck and my Silverado is in my shop with the bed cut up and installing patch panels since I backed into a tree. :D
I need this Ranger up and running. I'm on call 24/7 as a biz jet mechanic. Jets are easy for me, I have access to all the schematics and tech info I need
Wicked_Sludge
42
Westport, WA
3-point-GO
the theft light doesnt flash error codes, it just flashes. your key isnt communicating to the security module anymore. youll have to have the dealer repair the problem, since only they have access to the security module for key programming and the like.
Earl43P
38
Farmington, Pa
Ford F250 4WD
At the very least, check the fuses. In 2000, they were #19 and #26, side of the dash fusebox.
addiman09
Lago Vista, Texas
2.3 Liter DOHC 5spd
ignition may have come unplugged for some weird reason??? :icon_confused::icon_confused:
mikenbecw
Did you ever find out what was wrong??
I have the same problem, 2002 3.0L 5spd, I took it to a locksmith who cut me a couple new chip keys and was going to program the keys/truck but said his device was unable to communicate. http://www.therangerstation.com/forums/images/smilies/icon_confused.gif
The truck sat for 5 months with the battery disconnected before this happened.
I can get it to turn over by shorting the terminals on the starter, if I had the key on and the clutch engaged when I did this should it start? (no chip key and theft flashing)
Any ideas for some quick/somewhat easy tests?
I have a Diablo Preditor for my 08 diesel, should I be able to at least communicate if my ECU is working?
Thanks for any input.
7.5L_STX
73
Up Dere In Da U.P. EH!
unnecessary
if you jump the solenoid and have the key on and the tranny in nuetral it should start. thats how i used to start my 91 everyday lol.
mikenbecw
I tried it and it did not work for me.
I think I will try taking the PCM from the 2003 parts truck and try it, it has a chip key also.
I tried the Diablo Predator also but it kept saying it could not read the error codes. I tried swapping the diodes from the 2003 as well with no change.
It would be nice to be able to narrow this down instead of having to load it onto the trailer and haul to town after each change but I may have to take it to Ford soon as I am almost out of ideas.
