help setting timing
Mark01
ford ranger
Well i managed to get my truck started, but i was looking in the haynes manual and it says in order to set the timing use the SET TIMING CONNECTOR or the SHORTENING BAR. i need help locating them. Any help would be greatly appreciated. :icon_confused:
3,632
On the passenger side of the intake, near the middle runner, you will find a small 2-wire plug that just has a little slug in it. That is your SPOUT connector "shorting bar". Remove that slug and you will disable the computer's ability to actively advance or retard the timing, allowing you to set it.
Make sure to put that back in when you are done or you will have no power when driving.
Mark01
ford ranger
This?
3,632
Sure looks like it.
The easy test is to hit the crank with your timing light and watch to see the timing dance, then pull the plug and see if it settles down.
Mark01
ford ranger
Thank you for the help
Mark01
ford ranger
It was a bad coil wire but I still need to adjust the timing slightly
Mark01
ford ranger
Can I set the timing just by Turing the distributor and using a timing light?
3,632
That is the preferred method.
Mark01
ford ranger
Thank you
Rick W
October Truck of The Month
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
