Help! Differential Spider gears fell out!
tekkatekka
6
ford ranger
1991 ranger 4.L 4x4. I was replacing rear axle seals and the spider gears fell out. I was able to get one back in but can't figure how to get the other one in.
scotts90ranger
5,922
Dayton Oregon
2.3 Turbo
You have to get them across from each other. You should be able to get one in then rotate one axle shaft or the carrier so you can get to the opposite window in the carrier to get the other gear on or get the cross pin hole crosswise and get one spider on top and the other on bottom then rotate the two gears so they line up with the cross pin hole and stab the cross pin back in
tekkatekka
6
ford ranger
Thanks, I will give it a try and let you know how it works out.
lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
8,256
Butler, PA, USSA
5.0l
4”
Yeah, gears can be a little finicky to get in there. I’ve already temporarily put the cross pin back in after pulling the C-clips when doing this just to make sure the gears don’t walk out on me.
Similar threads
Truck of The Year
Kirby N.
2024 Truck of The Year!
Vagabond Video
