HELP! 3.0L V6 Duratec con rod bolt torque.
Otis413
117
Cass, WVa
4.0 SOHC
I can't find this information anywhere, a google search brings up lots of info for the Vulcan V6 but nothing for the Duratec V6 (DOHC).
I have a 2011 Ford Escape with a 3.0L V6 FlexFuel Duratec DOHC engine, a tapping noise led us to pull off the oil pan and turns out it lapped a connecting rod bearing. A bit of clean-up work and the crank and c-rod look good. I ordered the bearings from RockAuto but I can't find the torque sequence for the connecting rods anywhere...
Any help would be greatly appreciated.
Otis413
117
Cass, WVa
4.0 SOHC
Ok, got up early thismorning and made the two hour round trip to town, paid $25.oo for a Haynes manual, so just for the record:
Duratec 3.0L V6 connecting rod bolts, torque in two steps, step 1: 17 ft.lbs (23Nm), step 2: 32 ft.lbs (43Nm)
Source: Haynes Ford Escape and Mazda Tribute 2001-2017 book # 36022
Otis413
117
Cass, WVa
4.0 SOHC
I'm sure everybody's been on the edge of their seats about how this turned out, well so far so good, we got everything back together today, (BTW, aluminum bearings? I guess I'm just behind the times, and I reused the original con rod bolts) Mobil 1 synthetic 5w30 and filter. Let it idle till it was warmed up and took it for a test drive, sounds and feels like its old self.. I'll take it easy for the next hundred miles or so, under 3k RPM, I really don't like those aluminum bearings.
Fingers crossed! :)
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Otis413
117
Cass, WVa
4.0 SOHC
Uuugh, the con rod must have been damaged, it started knocking again last night... I guess I'll just park it till we can find a good used motor, if not it might be a winter rebuild project.... Oh well, just out $30.oo for the bearings and $35.oo for the oil and filter... and time... :-(
