Hello with a question
PNWcossack
Bellingham WA
Hello Friends,
My buddy gave me his 97 ranger that was destined for the junkyard, until he offered me to take it from him. It comes with a canopy and I plan on getting it running for truck camping this summer. I look forward in getting involved with the forum and sharing on what im doing with the truck.
It has the 4L v6, but it has blown heads. I have been tearing into it for the past month and I am down to the block. But I may have made a grave mistake of assuming what engine is in the truck and ordered new cylinder heads from King Cylinder in a rash manner. I have deduced that my engine would be a 95TM,(according to King Cylinder site 95TM,98TM are years 1995-2000, and 90TM,93TM are years 1990-1994) So I ran with the 95TM. Now is the time to put on the new heads, but the heads are not wanting to sit flush by themself (see image three) Perhaps this is normal, and the tolerances for the two posts are very tight (see image seven with P1 and P2 highlighted to see what I'm refering too) and I need to just tighten them down, everything does seems to line up perfectly. If this is the case please advice.
Question Given the photos provided, can you please help me identify my engine, there seems to me some contradictory information. Such as the passager cylinder head reads 95TM6090AD(see image six), but on the front of the engine it reads 90TM-6059-A1C(see image five) I have also included an image of the passanger exhaust manifold(see image four) door sticker(see image two) if that helps. Thanks in advance.
  • Like
Reactions: gaz
JoshT
3,430
Macon/Fort Valley, GA
P1 & P2 are dowel pins for head to block alignment, they can be a tight fit. If those are new heads the holes should be clean, but doesn't hurt to check. Also make sure that there are no burrs or lip on the dowel or holes in the heads. Try using a mallet (a mallet, not a hammer) and see if you can bump them down into place. Even if that doesn't work they should pull down when you tighten and torque the head bolts.
90, 93, 95, and 98 are design codes, they give the year that the design was made or entered production, they did not change every year. Code on the front of the engine was for the block. Not uncommon for it to be an earlier casting design than the heads. Pure memory here, but I think that the 90 block was used until the 98 block came out.
Sounds like you've got the right stuff to me, just got to check it over and put it together. Good luck with it, should be a good little truck when you get finished. Don't care for the light bar on the hood, but the shell by it self was worth getting the truck for IMO.
PNWcossack
Bellingham WA
Thanks for confirming for me Josh. I will proceed with installing the heads tomorrow. Ill keep you guys posted.
I agree with you with the light bar, but I can't help and wounder how bright it is. Might be useful with speeding down a forest road haha. According from the friend that got the truck from, that light bar is off a BNSF(local train company) maintenance truck. I'll keep it until I find a hood that I can replace it with.
I will also be getting new rims and tires for the truck when I know it is in good working order. Trying to see if I can get some BFGoodrich trail-terrian A/Ts with some black steeles. Im pretty confident that some 235/75R15 will fit without any modifications to the truck.
gaz
799
Wa, Bremerton 98310
Ranger 5" (1½" Hiryder/3" body), BII 4" Procomp
Ranger 5sp, BII A4LD
Ranger 32"/4:10LS, BII 33"/3:73LS
@PNWcossack
There is a top and bottom on those head gaskets. The heads and intakes are required to be installed and torqued simultaneously.
From the pic, it looks like your lower intake manifold may be sitting a little low; it is possible that it was milled to match a previously installed set of milled heads.
Wether you purchased new or reworked heads, they will benefit from a performance valve job. Those look like aftermarket wheels to me, what size rubber are on them?
Hello from Bremerton ..)
JoshT
3,430
As Gaz said definitely pay attention to which direction the gaskets are facing.
Gaz, as many time as I've done 4.0L head gaskets, and as many times as I've read various instructions for installing them, I've never seen anything that said the heads and intake need to be installed and torqued simultaneously. Every set of instructions I've ever seen for building a 4.0L OHV has you install and torque the heads, then install and torque the intake. Any chance that you could share those instructions or where you found them? I'd just like to give it a read if possible.
Which pic? I'm not seeing a lower intake in any of them.
SenorNoob
TRS 25th Anniversary
1,585
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Intake and heads together is in my Haynes/Chilton manuals. I'll edit with a pic soon.
Edit: Here ya go.
superj
3,849
corpus christi, texas
ranger edge
182 ci of tire shredding power
2, so far
235s
drives a stick shift ranger
welcome!!
great looking truck for the best price!
JohnPsz
11
Portland, OR
If you are trying to put the head on with that front dowel not square to the block, then that is why you are struggling. The one you have marked as P2 is not fully seated and square to the block (at least when that pic was taken it wasn't) and is getting bound up on the head as you try to install it, as other mentioned tap it in flush (a soft mallet or dead blow is better than a hammer) and check for burs after tapping it into the block.
Oh, and Welcome to TRS from some random dude in Oregon...
JoshT
3,430
Edit: Here ya go.
Interesting, the Haynes manual (2005 printing) sitting open in front of me has your steps 1, 3 and 5, but not steps 2 and 4. Even the step by step for the head install procedure does not mention doing them together.
Maybe the bolt instructions themselves did, but it's been long enough that I can't recall or certain. New Felpro bolts every time I did them, and followed what ever instructions were with them, but it's been several years since the last set and I don't recall doing it that way.
SenorNoob
1,585
Middle Tennessee
245-70-R16
The only reason I can think of for that is that someone thought it was necessary then found out it really wasn't. The book I took the picture of was apparently a 93 print Haynes. I have 92 book that is the same. This is a 99 Chilton:
JoshT
3,430
Looked up the Felpro bolt set instructions on their website and it says the same about alternating between the heads and intake. I guess I was doing it and just don't remember it. Or maybe dad did that portion of them. Most of it was done in his shop and he has a habbit of doing things while I'm at work instead of leaving it for me. Not complaining there, I'm happy that he feel like doing the stuff.
Okay...
So, what if only the lower intake needs to come off for what ever is being done? Not questioning you, just trying to make sense of the logic behind the instruction.
I'm not seeing any. If it were that critical, you'd have to remove and retorque the heads any time the lower intake was removed, but that isn't the case.
SenorNoob
1,585
Middle Tennessee
245-70-R16
I'm guessing it's because the heads have a little bit of slop. You can move them around with the bolts loosely inserted. If you are just pulling the lower intake, the heads are still in the same place. Once tightened down they won't move.
Similar threads
Truck of The Year
Kirby N.
2024 Truck of The Year!
Vagabond Video
