heater control valve help!!!
danczern90
What's up guys? I have a 95 ford ranger 3.0 that keeps blowing out heater cores on me. It all started when I got the trans rebuilt, then flushed the coolant and changed the stat. First few months were fine, then it blew out again. Replaced it, then it blew out 3 weeks later. Now I'm on my third replacement and I have a feeling it is because someone deleted the control valve. I need to figure out where the vacuum for the heater control valve goes to so I can reconnect it. Any help would be much appreciated. Thanks.
8,370
My '94 4.0l doesn't have a heat control valve, heater core has coolant passing thru it all the time, it is the by-pass for the water pump, engine would over heat if a valve was installed.
I know this because heater core got partially clogged and the engine temp would randomly spike, then go back to normal.
Replaced core(after a few other parts that didn't help, lol) and all has been well.
Make sure you are running a 192deg or 195deg t-stat, and if 3rd core goes try a different brand.
How are they "blowing out"?
older cores can rust thru, new core blow out could just be bad soldering.
martin
26
St Bruno, Quebec
1991
Bad rad cap can cause excess pressure in the system.
