franko0_2
- Aug 19, 2018
- 1
- canada
- Ford
- Engine Size
- 4.0
I was having some lighting issues to the rear of the vehicle ( doing weird stuff ). So I cleaned all the connections and sockets (likely a bad ground or something) and everything is working as it should now. But now when the ignition is off and I turn on the hazard lights the headlights flash along with them. It does not happen when the key is on and everything else works perfectly. They only flash when the key is off and the hazards are turned on. Is this likely a multifunction switch issue
