Header Install - Bolt Fix
Uncle Gump
Forum Moderator
3,858
Plano IL
Lead, Follow or get out of my way
B.O.A.T.
Bust Out Another Thousand
I never had a son... but my oldest daughter love to do things herself. I was a pretty proud papa when she called the other day and said... "so these commercial ceiling tiles... you just score and snap them to size just like you showed me with the dry wall?"
Rock Auto 5% Discount Code: 7FA902352B4C01: April 5th, 2021
svtcards
51
Lyman maine
302
3'' front 4''back
Best penetration oil you can use is stuff called Aerokroil.a machanist I work with swears by it and he's been doing it for about 30yrs.i personally used the stuff as well.it ll be the last penetration oil you buy I guarantee it.you can get pretty much anywhere.hope this helps.
ericbphoto
I didn't do it.
Forum Moderator
5,042
Wellford, SC
6"
Aerokroil is awesome.
Dirtman
9,897
41N 75W
It's up there.
It's down there.
Round.
50/50 Synthetic transmission fluid and acetone works better than any store bought stuff. Shake well before use...
svtcards
51
Lyman maine
302
3'' front 4''back
I beg to differ
ericbphoto
I didn't do it.
Forum Moderator
5,042
Wellford, SC
6"
svtcards
51
Lyman maine
302
3'' front 4''back
Dirtman
9,897
41N 75W
It's up there.
It's down there.
Round.
Uncle Gump
Forum Moderator
3,858
Plano IL
19Walt93
1,452
Canaan,NH
351
3"
235/55R16
I like Cyclo Breakaway best. If you can find the old Ford penetrating oil with graphite it works good but is a lousy lubricant. After soaking the bolt and drilling it out, try tapping around the bolt with a hammer before attempting to extract the old bolt. And go easy with the extractor, once you snap it off it's too late.
Blindmullet
7
Florida
I whimped out. I could have put the screws to it but backed off. Ran it up to a 1/4 with a handfull of bits. I was able to get a great bite on it.
Going to get the rest out tomorrow and throw an insert in it. His gaskets dont come until next week.
rumblecloud
154
Michigan
Ranger Splash
Stock
Stock
What's the worst that could happen?
Blindmullet
7
Florida
Put the header on today. I had to cut the rear driver's side bolt down a hair. There wasn't a way to insert it as it was too long. No leaks and does sound a bit better.
The dipstick tube makes contact with the header. Any issues here?
ericbphoto
I didn't do it.
Forum Moderator
5,042
Wellford, SC
6"
Probably not, other than maybe being extra hot when you pull it. Shouldn't be too hard to carefully tweak it away from the header. Maybe use a tubing bender so you don't kink it.
