Have you ever seen a Whale on a creeper
bcapel
Florida
Call me Geezer, 67 years old, 300 Lbs and the proud owner of my first Ranger, a 1996 4.0 STX 4X4 auto.
I bought the truck with a blown engine (locked up) I have some experience having been (now retired for 10 years) a ford
drivability Tech for about 15 years, give or take a few, you need help with eec 4 I'm your guy.
I could use a ton of help. First, getting the old engine out --- any tips or tricks?
Dose anyone here on TRS have any first hand experience swapping a 97 4.0 into a 96 truck?
I know the 97 flex plate has to be used and probably the 97 starter as well (different part numbers)
The 97 used a different auto trans, will the 96 trans and converter bolt up to the 97 engine?
anything else I need to know?
Having spent days reading in the forums here on TRS I know you guys will come through,
SO, A BIG THANKS in advanced
snoranger
Forum Stuff Member
Forum Moderator
ASE Certified Tech
11,434
Jackson, NJ
'79,'94,'02,'20
All Fords
Dose anyone here on TRS have any first hand experience swapping a 97 4.0 into a 96 truck? Yes, but not me. I have swapped an '01 SOHC into a '95 Exploder using the OHV computer... close enough. :D
I know the 97 flex plate has to be used and probably the 97 starter as well (different part numbers) Just leave the '97 (probably an 8 bolt) flexplate on the '97 motor, it will work. The only difference in starters is auto or man trans.
The 97 used a different auto trans, will the 96 trans and converter bolt up to the 97 engine? Yes.
Welcome.
See my answers above.
bcapel
Florida
Thanks for the quick reply, you have been a big help
