Hard drive?
gungfudan
19
Mississippi
Mazda
N/A
N/A
Hard drive? SOLVED
How do I wipe a hard drive?
That depends greatly on what operating system is already on it.
gungfudan
19
Mississippi
Mazda
N/A
N/A
Windows XP media center edition 2005
Are you upgrading to 7 or something?
Easiest way is to put a Windows install disc in, boot from that, and use the format utility.
multiranger
Praise the Lowerd!
MTOTM Winner
17
Loganville GA
Go to start and in the run command type CMD then type format ?:\ ?= drive letter. or go to my computer right click drive you want to format then click format.. other option you will need to boot to a disk like adsm 08 suggest...
gungfudan
19
Mississippi
Mazda
N/A
N/A
My operating system is jacked up. I can not load windows is there any way to do it without using windows?
I would try a repair install from the disk. I would not other trying to format from the command prompt in Windows anyway. It seems to not like trying to format a mounted drive.
gungfudan
19
Mississippi
Mazda
N/A
N/A
I have no disk
Well if you don't have a disk how were you planning on using the computer after you wipe the drive?
gungfudan
19
Mississippi
Mazda
N/A
N/A
Buddy of mine will get me one
So get the disk first.
deathwheeze
Chehalis, Wa
You can get linux it is free
martin
26
St Bruno, Quebec
1991
Drives are cheap now. Just put a hammer through it and buy a new disk, save yourself a lot of trouble.
AllanD
134
East-Central Pennsylvania
1987... sorta
'93 4.0
Drives are not cheap at the moment and there's never a purpose to wasting anything pointlessly.
AD
gungfudan
19
Mississippi
Mazda
N/A
N/A
Ok I found the recovery disk and recovered it to it's out of the box settings. I have been trying to download updates but this is the error i keep getting; Error number: 0x80244019
What can I do?
