corerftech
- Apr 22, 2021
- 99
- Memphis, TN
- Ford Ranger
Backstory broad strokes:
Carbureted my 01 Exp 5.0 with a squirt TCU, asking why will be futile.
Hack #1: Purge Valve Modification
Only a few caveats exist for the conversion and I know them all.... one is the purge valve for the vapor canister.
In an attempt to make things behave like the EFI but run a carburetor, I dont want fuel smell, I dont want vapor accumulation under the car and certainly not under the hood where Ill smell it as well. I also want to actively be purging the canister at least as well as a 1972 Ford truck would have in 1972. The factory of course uses a 12v solenoid purge valve that gets a signal from PCM, that opens a needle valve which lets manifold vacuum pull a large diaphram with a twin seal out of the way, thereby connecting the vapor can line to the manifold vac port/PCV system under the appropriate conditions.
I am cheap. Initially I was going to use a GM vacuum switched purge valve as a contemporary analog device. Thats another $40-50 so screw that!
Last night I decided that the purge valve was pssing me off and making me think to hard to find a way to bypass it. You may say, "thats easy". No it is not. Bundy connectors are used for both in and out. Two differing diameter Bundys, 1/2 inch and 3/8. The 1/2 inch is a "nylon" hose extension from a steel line as far as I can see and is the input. The output is just FI hose with Bundy to barbs, that part is easy. I found parts ot help but again, another $25.00. You mess up a nylon hose under your Air Conditioner compressor and you rapidly become an angry person.
So I removed the entire bracket with purge valve and found it was quite easy to disassemble. I will post some stills of the modified device later tonight.
Essentially it is a clamshell. Take the electric half off to expose a large return spring, a diaphram with 3 separate seal surfaces and a plate with two orifices. The diaphram has a major diameter outer seal that seals the clamshell. The inner diameter is for sealing the INPUT channel cast into the plate. The center of the diaphram has a TIT that is like a pencil point, and it PLUGS the OUT to manifold orifice. At rest the diaphram simultaneously blocks the CHANNEL, the ORIFICE and maintains a seal on the clamshell. When vacuum is applied from an accessory tap by the solenoid, the diaphram is sucked away from the platter, opening both channel and orifice linking them.
The hack is to both maintain the clamshell seal integrity but loose the dual seal integrity permanently. Once opened, I removed the return spring as there will never be high vacuum applied to the system. Second, I added two BUMPS to the platter surface causing the dual seal to see a lump rather than a smooth surface to seal against. Lastly the center of the diaphram is aluminum and I hammered a small dome into it so that it could not seal the old TIT/Orifice even with the silicone TITcut off. Under test even with tit removed, the flat center of the aluminum did effective seal about 90% the orifice.
Essentially the diaphram is now unable to seal except the perimeter of the clamshell. You can suck/blow with very little restriction. I effectively married the two ports making a butt connector out of a purge valve. I get to use the factory hoses in total, the valves outlet will feed the air cleaner base plate port with the 3/8 OEM hose which happens to be the correct length to get there.
Thats the hack. It is a rare situation I believe I created but Ill bet someone else on some other later model RBV(ish) car may desire to link the purge line to the carburetor region of the engine cheaply on their converted EFI to carbonator system. Could be done on any car with a purge valve, at least from Ford. I have seen quite a few purge valves from Fords and they all seem to be built similar.
If you were wondering why I did not just power the solenoid, I dont believe the device is rated or designed for continuous duty. It would smoke later on and stick closed.
Hack #2: Coolant temp sensor (gauge) location for the Edelbrock Performer 289 manifold with HEI distributor combo
The 289 manifold will accept the EFI T-stat housing. The manifold T-stat port opening is significantly further forward than the EFI manifold. Therefore the Water Pump shot molded bypass hose cant be used. Making matters worse, the HEI distributor is so large in diameter (large cap/coil version) that the normal location for a gauge transducer is covered and too close to distributor to fit. Interestingly the OEM stat housing has a cast recess that has not been drilled or tapped, for a coolant sensor. Even worse, the thread pitch of your "reused" efi sensor is 16x1.5mm pitch, not 1/2 NPT like the manifold wants. What to do???
Plug the driver side 1/2 inch port in manifold.
Either buy a Drill/tap kit for 16x1.5mm and thread the OEM stat housing or buy a Dorman replacement. The Dorman is JUNK, aluminum and will have more casting slag, chips, burrs and crap than the floor of a foundry. But it has the 16mm port already D/T and has a plug in it. Remachine the housing with a file to remove what they left in China, remove the plug, install the sensor. It will clear the HEI housing by 1/16 to 1/8 depending on how you clock the sensor and that is with the single wire OEM connector attached. Excellent position as well.
Hack #3: Performer 289 distributor relief cut
There is a boss that is cast into the manifold and it will interfere with the HEI distributor cap CLAMPS and a uninterrupted rotation of the distributor for timing. Before manifold is installed, deck that boss where it can be seen to interfere with the base plate of the HEI. On mine, I got 1/16 inch relief from the boss with a few minutes and a file.
Hack #4: HEI dist orientation
At 15 degrees BTDC on your installed crank timing tape that was indicated by a piston stop before you installed it........
Point the rotor button at the area between cyl #1 and 2 as you install the dizzy. This will place the vac advance can approx 4 o'clock as seen from front of car. This will both clear the A/C lines, alternator wire, PS pump stuff, etc (re: the vac advance can nipple), will place it in a short but sweet relationship to the carb manifold vac nipple (edelbrock carb) and also allow you to route all HEI harness wires cleanly to the C115 harness connecor on firewall.
The #1 plug position on dizy shall be at 7 o'clock with the HEI wire connectors at 6 o'clock. 13726548 and your done. As well you can reuse ALL the spark plug wire management clips for a relativey clean, free wire management.
Lastly, you will also gain even more clearance from the CAST BOSS on the manifold mentioned earlier.
Hack #5: Water pump bypass line
No hack, just a crappy situation. The Stat housing is SOOOOOOO far forward that unless you make a 5/8 hard pipe, you can't get the two nipples, housing and pump, to connect. So no hack.... pulg both sides and live with it.
Really the hack is to drill and tap the housing port for a plug. A Dorman replacement would be necessary. Remove the expoxied 3/4 inch hose nipple, then D/T carefully but not so deep as to alter the housing gasket surface. It was too risky for my timeline to do so. If I screwed up I would have had to tap the OEM housing for 16mm temp sensor, and my old housing was done for its service life. I did not take the risk but it is clearly doable. one migh also have success simply doing as Dorman did, but with a solid smooth sided plug, epoxy the port. Make a steel plug, not quite interference fit, maybe .001-.002 loose and then use appropriate epoxy. If the plug is short enough, you could then PEEN the front edge to secure the plug as well as seal and glue.
Hack #5: A/C lines (the big fat hard one transverse to engine!)
Hack is to remove the bracket that secures it to the alternator (leave it on the A/C line, remove from alternator.
Then you and a friend (I did it by myself and it was all I had in me), bend the hell out of it. I am a 30 plus year veteran electrical contractor, so I used my special 'Trician powers to bend it just right. Support with one hand and pull like hell straight up. This will relieve the Vac Advance can for access and rotation as the dizzy and the A/C interfere badly. Dont be gentle or careful, it needs to move a LONG ways up and will then pose an interference for the upper rad hose. All is well, keep bending it up, it has plently of give and room below the hood.
You will need to lengthen the hose bracket to alternator with a metal strap. That will be obvious how to do. You dont want that hose to flop around as it will produce a leak later at the filter/drier coupling.
Hack 6: Where to install the Microsquirt TCU?
Remove your glovebox by squeezing the sides, it will flop down to the floor. There will be a defroster hose and some orange insulation. Driectly behind that is the old PCM firewall pocket. Run the TCU harness from the left side of the glovebox, behind the defroster hose and it will thread right into the PCM pocket. The TCU will live to the left of the glove box behind the A/C controls, plenty of room and your serial port access could not be easier for tuning. The PCM pocket will be sealed by the original cover, drilled for a gland to maintain water/air tight. Harness emerges less than 12 inches from the C115 firewall harness connector where it will marry with both the instrument panel, the trans harness, the ignition as needed. A 3 foot TCU harness is plently long with some to spare.
Hack 7: A messed up EGR boss on the passenger exhaust manifold
Luck me, someone had fixed the EGR a long time ago. Really fixed it. I had to find a simple way to plug the EGR boss. I tried to buy something, not happening. It is a unicorn. So, 3/4 inch NPT drill and tap, while in car. Kleenex stuffed both directions in the EGR boss to stop chips from moving to bad places. Liberal cutting fluid. Appropriate drill (its cast iron and butter soft to machine), drill as deep as you can! There are steps in the boss and those will be an impass for the tap to cut.
tap it (thats a big tap so expect lots of in/out/chip removal and slow progress by hand), vacuum it (Kleenex then exists naturally with chips, if not, set it on fire with torch). Amazon 3/4 inch NPT stainless plug. Use an impact to install it and send it with 200 lb/ft. When the Milwaulkee impact stops, its done. No leaks.
Hack 8: Spark plug wire heat protection
Due to HEI, needed custom wires. Good luck reproducing cheaply the Motorcraft aluminum heat shields. And they will not transfer to other wires.
I intended to terminate the OE cables to retain the factory boots/shields, the wires are simply too short for the dizzy install.
Moroso $39-49 Amazon kit, generic 8mm, with 45/135 boots. Includes HEI ends.
A plug wire crimper (proper, Titan brand or similar)
Take the old ford aluminum shields apart. Take the straight tube section, remove from boot and shorten the back side with tin snips. You want the spring to stay in, you need it. Install that on the plug end of the wire, it wont stay by itself very well (yet). You will need to alter the tube so that the end you cut cant cut into the boot, bend a radius into half of it. Sharp edges and spark plug wires are not a good thing.
Amazon, $12.00, 2500'F fiberglass heat sleeves for LS engines, and also use the old Ford aluminized sleeves as well. The more wire shielded in length the better.
Install the plug wire end with the shortened metal sleeve on the desired plug. Slide the amazon sleeve (and or OE sleeve) down to the boot and then thread the sleeve onto the aluminum tube so that they become one. That reporduces as best possible the 145 degree solid aluminum heat shield as found on a factory wire set.
Of course you only need to do this at a few plugs, the balance just get an Amazon sleeve.
Cut and crimp perfect length wires to your dizzy.
Hack 9: Remove the old air filter box.
Not a hack, it was just phun and made me happy.
Hack #10, Fuel pump
A hack or maybe just a rework, depending on your desire.
I replaced the fuel pump 2 years ago, in tank EFI. It died again and in concert with the PCM coil drivers. Bye Bye in tank pump.
I installed a low cost, easily serviced frame mounted carb pump and needed to mod the tank pickup to make that work.
A 3/8 stainless tube (Amazon, from another project) of about 12 inches replaced all the parts in the tank hanging on the pump hanger. It is a siphon straw about 1/4 inch from bottom of the tank. there is no return line on the 2001 chassis so easy for me.
Along with pump, the OE line was reused.
Buy a Ford QD to barb adaptor. This will couple a 3/8 fuel hose to the EFI stainless fuel line. That will feed your carb adjustable fuel pressure regulator and done.
Hack #11, timing tape
Use spark plug piston stop to generate the marks, split the difference precisely with a tape from under the car. Once you have teh split marks, manually turn the engine over so that you have access to the business side of the damper laying on your back. Use white paint pen very fine for the split marks. Sand the damper to bright metal prior to attempt. Mark TDC center, use small file to notch the edge of damper. If you trust the white paint pen, when you spray clear it will wash off. MAKE A NOTCH! Spray CLEAR rust oleum on the damper wherever your MSD/Holley timing tape will be. A light coat. Let get tacky but not dry. Apply timing tape carefully. Wait 10 mins. Respray the entire tape/damper affected areas with clear again.
Walk away for 24-36 hours. Timing tape should be semi-permeant like maybe 10 years permanent. The notch will guide a reinstall if it does fail to stay at some point.
I think that is all for now, I will post more when Air Condtioning is reactivated as it requires some intervention for absolute factory control features.
Pics forthcoming to help make sense.
For the TCU and harness changes, the 2000 Helms Elec manual is your friend. I may create a schematic PDF for the conversion that will save some folks some time. I have many, many hours of turning pages and creating offset sheets between devices to ensure my first start was perfect and everything works as it should with no wiring errors.
Hack #10, Fuel pump
