Guide rig
Clarkmarine10
Utah
Ranger xlt 4.0
What’s going on everyone!!! I got a 97 xlt 4.0 4x4 I just purchased a leveling kit and 4 shocks from rough country and having 31 10.50 put on the factory 15 in wheels. I guide for elk and deer in the fall and this trucks primary purpose is that. Does anyone have drawing or good pics for a front winch mount The front receivers I’ve seen online sit to low and would be problematic for ground clearance. Any help with s drawing or photos of a diy winch setup would be awesome. As I’m not interested in a aftermarket modular bumper
dustyrangers
57
Colorado
Ranger 4.0 4WD
PO made the bumper and mount in my profile pic that I had a 10k warn on until recently. Still have it but some of the main welds are cracked (this PO really knew what he was doing 😂) and I am trying to think of ways to mount it behind the grill now.
85_Ranger4x4
17,822
SW Iowa
That is the downside to receiver mounted winches, they hang down low.
I am wanting to either track down or reverse engineer a Warn Transformer grille guard which had a winch mount built into it so I can keep the stock bumper.
Junk Collector
Truck of Month
4,798
Rapid City SD
On my '88 I cut a square hole through the middle of the bumper and mounted a "hitch" right behind that...basically a piece of square tubing bolted between the frame rails with a 2" receiver tube welded perpendicularly to it. Depending on your fabrication skills and desire to cut a hole in your bumper, you could go that route... it was pretty easy to build and keeps the winch up at bumper level.
Clarkmarine10
Utah
Ranger xlt 4.0
I was kind thinking the same thing. Just running a 2x2 .250 sq tube between the frame rails perpendicular. It won’t make a hell of a radiator guard as well I wonder if it would be sufficient for a 5000 lbs winch
Junk Collector
Truck of Month
4,798
Rapid City SD
Should be fine within reason. I'd probably put at least an 8000lb winch on your rig...that's what I have on two of mine, Smittybilt XRC-8's. I think that's about the minimum you should run on anything bigger than an ATV.
Clarkmarine10
Utah
Ranger xlt 4.0
It would be used for logs mostly possible self recovery but it would be minimal
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Buy once cry once.
Welcome to TRS...
