Good evening
ChiefJJ
5
Fort Leonard Wood MO
Hey y’all I’m new here, I have a 2011 Ranger that I would eventually like to turn into a dually so any suggestion's or guidance (other than negative) would be greatly appreciated. The red is my current the gray is my goal
ericbphoto
Overlander in development
15,987
Wellford, SC
6"
Welcome to TRS! Sounds like a fun project.
8,194
If you want an actual dually that can handle the weight then F250 superduty dually rear axles are usually not hard to find
Then you will need to shorten it and add the spring perches and shock mounts, and pinion/yoke adapter
But pretty sure you can't get higher load or tow rating unless you pay for full inspection and get a new title as a custom vehicle
1999 and up use 8x170mm lug pattern, so you would need adapters for the front wheels so they match
I think they used to sell "dually spacers", or you could have them made, these were ONLY for the look of duallies, and can not handle extra weight
But way cheaper way to go
Dantheman1540
454
Florida
Not being negative just curious what the goals besides having a dually appearance are? Do you actually plan to tow? If not the dually soacers are much easier to do
dvdswan
2,859
Seattle, WA
Ranger XLT 2WD
Welcome to the site.
pjtoledo
2,823
Toledo Ohio
Fords
3.0 2.3
nice Rangers. good luck with the dually build.
I did basic training at Ft. Leonard Wood way back in '72. November & December. 'twas a bit chilly
Lefty
1,760
Saint Paul, MN
Ranger Edge
Kelvinf
19
Independence Missouri
Ford Ranger XLT
245/70R/16 Venom Power Terra Hunter
When you say something will only take a couple of hours it usually takes longer.
Yotaismygame
February Truck of The Month
