2.3L ('02-'11) Good compression, misfires and oil consumption
mja_ranger04
Denver, co
Ford ranger
Hey y'all, I am in some real need of real tech help.
I have an 04 ranger 2.3l, 201k miles.
1) It uses a high amount of oil, looks dirty soon after an oil change, with almost a silvery tint to it on the dipstick. The engine doesn't leak a drop of oil and the exhaust is normal. Where is the oil going?
2) I had a MAF trouble code come up, changed air filter and the sensor, cleared the code and hasn't returned.
3) when I am driving, I hear a pinging/rattling noise at half throttle coming from the engine.
4) I smell coolant at times while driving, but have no leaks... And not losing any.
5) Now, I am getting p0301 and p0316 codes, and horrible hesitation and bogging.
Plugs, wires, and coil were replaced last year.
Fuel pressure is at normal range around 80psi
I ran a compression test today, all cylinders are at 180/185 psi.
I believe the injectors are all working.
What could the oil consumption be?
The coolant problem?
The pinging?
The misfire?
Mike
Josh B
1,057
Oklahoma
I think a bit of coolant is getting in the oil somehow. They have some simple tests for it but you'll have to wait on one that knows it well, I haven't really paid enough attention to any of those to give you clear details
UnNFormedFan
36605
I am having identical problems with my 2003 DOHC 2.3l. I have found that I am burning oil through the engine. I have determined that there is an awful blow by that is being picked up thru pcv system and introducing aerosol oil into the incoming air from air filter. Compression test all showed within tolerance but the oil is coming from somewhere. Inside of my intake is coated in oil. I'm stuck. I'm losing 2 qts oil with a tank full of gas. I ran Royal Purple exclusively but can't afford the $12/qt anymore. I haven't been able to affect consumption at all. I bought the truck new in 03 and have loved the truck but can't trust it for long trips anymore. Ill be watching this one hoping for a solution.
UnNFormedFan
36605
The above picture is what I found under the valve cover gasket when I pulled it for the first time ay 175k miles.
rusty ol ranger
Im a Jeep guy now.
5,032
Michigan
177 CID
The silvery tint is probably metallic shavings from internals getting destroyed
mja_ranger04
Denver, co
Ford ranger
So, where could the oil be going?
I am having a similar problem. I have yet to pull the valve cover off.
I had K&n filter installed and have since taken it out because i heard they cause problems with mass air sensors. When I removed the k&n, I noticed oil at the bottom of the air box... Odd. And it seems there is oil going up thru the breather tube on the valve cover, looks like oil is collecting around that. This is a weird one. So I bought a pcv valve to change it out because it may the culprit... Haven't done so yet. A mechanic guy said he doesnt think it would be the pcv since they don't do much... Not that I am trusting his word on that. I found a low mileage replacement engine and may just swap engines.
UnNFormedFan
36605
Mja, what i am seeing the oil is being aerosoled by being forced thru either bad rings or from valve issues. I am yet to determine if it is coming from bottom end or a bad valve. All of my oil is coming in air supply as it is coating the inside walls of the intake manifold. So, I know where it is going, I just can't figure how it is getting there. I do not smoke no am I losing oil thru leaks. I have been fighting this for a couple years. When gas went to $5 a gallon I just parked it but am back to figuring it out..
mja_ranger04
Denver, co
Ford ranger
Run a compression test, that will tell you if it's top or bottom engine, yeah? I ran one, and its fine.. Must be the head is toast... I also have oil coating my intake manifold but not past the throttle body.. Found it yesterday caked on. So this could be a damaged head/valves... ? I can't see how quarts of oil is getting past whatever in the engine and none is coming out of the tailpipe...
Josh B
1,057
Oklahoma
"I can't see how quarts of oil is getting past whatever in the engine and none is coming out of the tailpipe... "
My guess would be getting burned up, is it smoking at all ?
pjtoledo
2,056
Toledo Ohio
Fords
3.0 2.3
what do the plugs look like?
run a cold & dry compression test. that's 1 test
the excess oil is acting like fuel in the cylinder, the O2 sensors think the oil is excess gas so the PCM cuts the fuel back.
when my 2005 used massive oil it didn't smoke, the cats cleaned it up. at full throttle there was some smoke.
it would bog at lower RPMs, at higher revs it would start firing on all 4, sort of....
eventually compression on #1 dropped to 75 psi, and the plug would oil foul in only a couple hundered miles.
when I pulled the piston, nothing looked worn but the rings exerted very little pressure on the cylinder.
the other 3 were perfect.
the design of these heads has the cam followers, AKA buckets, shrouding the valve seals. in my opinion it's unlikely the valve seals are bad.
UnNFormedFan
36605
I'm told that a leakdown test is the way to tell top or bottom end. Compression test shows normal.
mja_ranger04
Denver, co
Ford ranger
Figured out the p0301 and p0316... It was the coil, even though i put a new one on last year... NGK brand... Found a Denso one off another Ranger... So that problem is fixed.
Now on to the
-Intermittent coolant smell
-The oil consumption (which may be a blockage not allowing the oil to drain back down?, therefore resulting in a false reading in the stick)
- and the pinging/rattling at half throttle (which may be related to the oil problem)
I'm going to use Marvel mystery oil and see what happens.
mja_ranger04
Denver, co
Ford ranger
Cold and dry test? Which is not to operating temp, and with all plugs out?
Plugs look normal.
Carlisle Truck Nationals
Join us at the Carlisle Truck Nationals for the 40th Anniversary of the Ford Ranger.
