Trump8MyKids
- Sep 29, 2020
- 37
- Fond du Lac, Wisconsin
- Ford Ranger
Had to miss school and work last Monday due to me having to drain my diff oil because my diff ate up my abs sensor (probably should have been a sign from the start). Something as of earlier today is making a terrible clunk inside of there. originally it happened whenever I’d let off the gas but now it happens regardless of my accelerator pedal position. I was told by somebody on here to check for play in my rear differential (wanted to check carrier bearings) but I later found out the parking brake was set by my girlfriend seeing I was on ramps and I didn’t set it. Not sure if that would affect the results. The noise only happens over 25 mph. Any ideas on what the noise could be? Everybody I have talked to about it is baffled, as am I. Any help would be appreciated!
