Ghost in the Machine
Zelix
34785
Ford Ranger XLT
I have a 95 Ranger XLT 2WD 4.0 that seems to have a electrical issue. It has 38,000 miles on it. It never holds a charge on the battery it seems, but if you go to jump it off, it comes to life right away. Literally you just touch the jumpers to it and it suddenly wakes up. Then once you start it, it will roll the drivers window only down in 3 to 5 stages to completely down. Now it seems to want to shift out of fourth gear into second. I thought at first that the tranny needed servicing, so I installed new filter and replaced fluid with new fluid. I thought I had it licked when 2 days later it came back. I have been reading that some functions are controlled by a GEM module, but as I read, nothing seemed to indicate it had anything to do with the tranny. Ocassionally a light would come on after one of these jump starts and was yellow and something about the overdrive solenoid. If you turned the truck off and back on, it went away and would not come back on till you had to rejump it. Same with the ABS light. Does anyone have some ides before I spend thousands of dollars on stuff I don't need to maybe or maybe not fix a electrical issue?
Eddo Rogue
2,497
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
You have a gremlin, possibly a few. They like motorcycles too. Once they claw their way in, its difficult to get rid of them.
You need a bell, but not one you went out and bought. it must be gifted or given to you. Gremlins hate bells, they will stay away. Hang the bell where they seem to hang around the most, it usually near their nest. in your case is sounds like under the hood somewhere between the engine and transmission. Good luck.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Sounds like grounding issues.
However, PCMs do not like to be electrocuted.
@RonD
8,369
"It never holds a charge on the battery it seems, but if you go to jump it off, it comes to life right away."
Get a Volt meter and test the battery, don't care if its brand new or 6 years old, TEST IT
Let battery sit for at least 4 hours before testing
12.8 volts is a new battery
12.5v is a 3 year old battery
12.3v is a 5/6 year old battery and time to watch for battery sales
12.2volts or lower is a failing battery, replace it
Battery can become self draining, quite normal at end of life, its an internal short, and it can happen on a new battery as well
You can unhook either battery cable and test battery voltage, write it down, then come back in 2+ hours and test voltage again, should be exactly the same, if its lower then that battery is self draining, period
Charging system test
After engine is started, battery voltage should be 14.3v to 14.8volts, under 15v for sure
After engine has idled for 5-8 minutes battery voltage should be 13.5v to 13.8volts under 14v for sure
If voltage stays higher than 14v then could be battery is bad, OR Voltage regulator is bad
If battery tested as OK the its the voltage regulator
Eddo Rogue
2,497
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Gremlins do like grounds
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Oh wait.... he said ghost in the machine, not ghost in the shell.
nvm.
19Walt93
4,458
Canaan,NH
351
3"
235/55R16
If you disconnect the battery and let it sit overnight, is the battery dead when you hook it back up? If not you have a current drain somewhere.
Ranger850
Doesn't get Sarcasm . . .
4,680
Tallahassee Florida
Stock 2"
Stock
