- Jul 6, 2024
- 3
- Minnesota
- Ford ranger
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
Sorry in advance for the long post but I have a 1990 ranger with the 2.9 and am having trouble locating where some of my plugs and vacuum line go below are the pictures of the plugs I cannot find a home for and a vacuum line that broke and Im not quite certain where is goes either I also am seeing if anyone knows what attaches to what I believe is the thermostat sender as well as what 4 things attach to the throttle body two of the hose nipples of the throttle body ive deduced to the pvc valve and crank breather but then theres 2 other small outlets on it that are open
I am also looking for recommendations on what oil you guys run after a fresh rebuild currently im looking at using valvoline synthetic with a quart of lucas zinc additive in addition to that recommendations on priming everything for the first start I am thinking of unplugging the fuel pump relay and running the starter for 5-10 seconds a few times to try and prime the oil pump but I am not certain that will be enough any insight is greatly appreciated since this is my first engine overhaul ive done and dont wanna mess up all the work ive put into this project all ready
