This is the eventuallity depending on goals .. I dislike trailers and towing...but when potential thrashing is on the agenda....a quality trailer is very handy.
I am older and broken enough that rebuilding the trans or engine or axle housing to go home is not just another bump in the road anymore ....
But for moderate stuff... Flat towing is cost effective. Way less weight
Maybe less weight, but very expensive OOPS when you forget to follow the proper flat towing preparation steps, as the PO of my 88 Bronco 2 did which took out the transmission as a result. In his case I think his mistake was he didn't disengage the manual hubs, so the whole drive train was spinning without any transmission lubrication for god knows how long. I'd rather have some extra weight and put the vehicle on a trailer.
Yep, the tow bar brackets are still on my Bronco 2, but they are now known as Fog Light brackets LOL, I made a couple plates and used the tow bar brackets as mounting locations for my fog lights as I have absolutely no intentions of ever flat towing my Bronco 2 not to mention I don't have the tow bar anyways so those brackets are useless to me otherwise. I don't even think they're mounted properly to actually legally tow it, as they're only mounted with 1 bolt through the frame, the 2nd bolt they just drilled a hole in the bumper and ran the bolt through, not sure if that's really the correct mounting procedure or not but I myself wouldn't trust towing it that way.
I wouldn't mind towing my 87 Ranger behind an RV because it has a manual transmission, still really hesitant to try and tow an automatic behind an RV....my luck I'd do something like the PO of my B2 did LOL.
