GAS TANK QUESTION RE: 94 2wd standard cab AUTO long bed
1996_XLT
Nawth Central Florida
XLT Ranger
Just purchased 1st Ranger, it appears I have the SMALLER capacity tank, will the larger one just bolt in as a replacement without any changes??? Would like more capacity. AND is the hard quick shifting of these trans normal?
meck
Madison County, KY
1994 extended c
I've never tried to put the larger tank in one, but I don't know why you couldn't. i have a '94 with the larger tank and a '97 with the smaller. the extra capacity seems to be at the front of the tank. For me, I would stay with the smaller tank just for the ease of taking it off. The longer one is a pita to work out of its place. As for the transmissikn shifting, mine shifts very smoothly.
gaz
649
Wa, Bremerton 98310
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
1996XLT:
If you want 23 gallons with a little effort, install an Bronco II fuel tank behind the rear axel; it requires that you lengthin the wiring/fuel lines a scosch and move your fuel fill access door to the rear. It is cheap, the difference between 17 gallons and 23 gallons is worth it.
From what I've read a full size Ford Bronco's 32 gallon fuel tank will also fit behind the rear axle; almost the same amount of effort and 15 extra gallons. Not plug and play by any standard but well worth it.
