professor229
- Dec 24, 2021
- 84
- Minnesota
- Ford Ranger
Guess I will admit I need advice on this one. I need to replace my fuel pump/sending unit and have watched numerous videos. I bought the replacement unit from A1 Auto because their unit has a limited lifetime guarantee. The 2004 Ford Ranger has a seven foot boxm 3 liter motor. This truck was totaled and bought back by my neighbor. It became my project truck for $500 two winters ago. I have done over 200 hours of restoration. When I bought it, the neighbor had replaced the alternator and the fuel pump/sending unit so I thought those would be "good to go" for quite some time. How silly of me. I am sure the mechanic who did the fuel pump replacement bought a $50 Ebay special with a one year warranty. My check engine light appeared and the code read a voltage problem with the sending unit. I have also noticed that it uses more gas than it should so I made the decision to replace it myself. I did buy a nearly new 7 foot box for the truck and replaced that so I do know how to remove the box and yes, I used anti seize on the bolts and the plan is to move the box back a couple feet to give me access to the fuel tank... this is sooo easy to do compared to dropping the tank. The videos show step by step how to replace the fuel pump unit except for one particulat problem. Every video seems to try to show how to remove the fuel lines to the unit in the tank.... except, the guy doing the work has his hands in the way so you cannot see how to remove the fuel lines and have to rely on his explanation. I don't want to screw this up so I looked at the OReiilys article on this and also have done some basic research on a tool to remove the fuel lines correctly. One video showed the guy using a longer tool, slipping it around the fuel line and simply pulling... and recommended the tool. There are other tools that look like an X with obviously two different diameters... to accomplish this. Then there are the videos that say "push here" or "squeeze here" after pushing in, squeeze and it will release.....Is it that easy? Is a tool recommended? I might stop in at OReillys and ask to rent/borrow a tool... since I don't really want to buy the tool for this one time application....
Anybody got any advice other than that? Can I remove the gas lines from the unit without a tool? Is there a preferred tool? Is there a tool to avoid? Does anybody have a link to a video that shows how to remove the fuel lines without a hand blocking the view?
Any advice/links/suggestions would be greatly appreciated.... thanks.... Dennis
