Dulis
- Sep 25, 2020
- Reaction score
- 1
- Location
- Canada
- Make / Model
- Ford Bronco 2
- Manual
Okay so I've got a no start condition right now in my '89 b2 with single pump, I've narrowed it down to the fuel system. It's not making enough pressure so I did a voltage drop test on everything from battery to pump. It looks good until I get to the inertia switch as in when I do the test on it I pulled the connector and tested the input wire because I'm lazy but assuming I had a good ground the meter read from key on, 12 something volts for all of half a second, then about 6 and a half volts continuous until key off (the fuel pump reads the same) . From what I've seen here the things upstream from that are the relay and computer, and I know the relay is getting the right power so I think it would mean the computer isn't working right for whatever reason. Anyway I'm kinda stuck here so what should I do next? Thanks in advance!
