MikeG
- Jul 15, 2020
- 752
- central Texas
- B4000
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 2WD
- Total Lift
- 2"
- Tire Size
- 235/75r15
OK here's my sad tale. Driving truck home (97 B4000 a.k.a. 4.0L OHV) from inspection (passed), it died at a stop sign and would not start. Suspecting fuel system problems, bought a gage. Zero PSI with key on, and no sound from tank. It was already having a problem not holding pressure after being shut off (had to turn key off and on 3 or 4 times, or crank a while) but otherwise running great.
Although the fuel pump relay clicked, the fuel pump was not making any noise. Jumpered the relay and fuel pump comes on, jumps up to 40psi then zero as soon as jumper removed. Bought a new relay from the 'Zone, same thing. Clicks but doesn't start pump, although jumper does. Checked the inertial switch, wasn't popped up.
So.... is 40 PSI correct at startup? Why would the jumper start the fuel pump, but not the relay? Is there something else that could prevent the fuel pump from starting up? I tried starting it with the jumper on the fuel relay, but no luck. However did not have the gage attached at the time.
thoughts? Tank mostly full, would hate to have to pull it. Guessing the bed would have to come off.
