2.3L ('02-'11) Fuel pump
BiggyB
New member
Sherman texas
Ford ranger
I’m new here, sorry if this is an issue that’s been discussed a million times I’m not sure how to navigate. I just purchased an 05 ranger 2.3 truck had no battery it’s out old shop truck a friend was going to buy it a few months back and backed out well I jumped on it. It had a broken spark plug wire and I replaced the battery. I don’t hear the fuel pump coming on and I have no fuel at the rail. I checked the fuse and the relay. Both are in good working condidtiom but the fuse is hot all the time is that normal? Also truck ran great off a single squirt of MAF cleaner. Just about order a pump and filter but thought I’d get an opinion. Thanks
Rock Auto 5% Discount Code: 32B05A80BF19AF Expires: July 1st, 2020
Uncle Gump
Forum Moderator
1,842
Plano IL
Lead, Follow or get out of my way
Use a jumper to bypass the fuel pump relay. See if the pump works.
BiggyB
New member
Sherman texas
Ford ranger
I used a power probe to check operation of the circuit and relay with 12v jumped the fuel pump did not come on
RobbieD
Well-known member
155
Georgia
Does an '05 have an inertia switch, like the older ones that I'm used to? I'd also try to check for power at (or close to) the pump before buying the new one.
