photopaul
- Nov 19, 2013
- 0
- Ford
I've been working on my 96 Ranger for 4 days now and I can't figure out why the fuel pump won't pump fuel.
I loaned it to my sister a while ago and she was responsible for the maintenance and when it died and wouldn't restart she took it to a garage for repair. They quoted $375 to replace the fuel pump.
I don't have a problem with the price (businesses need to make money) but on my old 96 Ranger with 200k on it I figured I would do it myself with Rock Auto parts ($50)
I removed the bed and accessed the fuel pump; removed the old one and installed the new one and no fuel would pump. It cranks fine, will run for a bit with starting fluid, I replaced the fuel pump relay though it didn't appear to be malfunctioning and verified the inertia switch was okay.
I get a brief 12 volts at the inertia switch and at the fuel pump connector then it drops to 6 volts like I have read it should and still no fuel. I removed the fuel lines to see if anything was coming out when I tried to start the truck and nothing. I removed the fuel pump and connected it to a 12v supply and the pump motor appeared to work. I re-installed the pump and left the fuel lines off and connected 12v to the pump directly and it pumped out fuel.
I jumped from the connector to the pins on the fuel pump with a wire to make sure there was a good connection between the connector and the pump and nothing.
Any suggestions??
Any suggestions??
