Alex_g
- Apr 23, 2020
- 1
- Washington
- Ford ranger
- Engine Type
- 2.3 (4 Cylinder)
- 2WD / 4WD
- 4WD
- Total Lift
- 3” block lift on rear axel no front lift
I've got a 92 2.3 and its throwing a 542 Fuel pump secondary circuit failure
and a 452 insufficient input from vehicle speed sensor
I drove out to the garbage dump no problem started it up and drove it a couple hundred feet to drop off my recycling and it wouldn't start. Fuel pump will prime once if you disconnect and reconnect the battery but then the starter will just click once like it has a dead battery every time you try to crank it after the battery disconnect.
I did a little diging on the forums here and the only solution i found was a bad ground by the electronic brain/ CPU on the utside passenger side footwell wall. I cleaned paint off the grounds buy the CPU and checked the inertia switch and still nothing.
Once I'm home where should I start looking? I checked my Haynes manual and couldnt find anything about a fuel pump secondary circuit.
