NIGERIAN RANGER
- Sep 13, 2020
- 28
- Lagos, Nigeria
- Ford Ranger
Recently after I had replaced another complete engine for my truck, I tried starting it but doesn't start. It cranks, but no start.
I have checked and replaced the spark plugs, and checked for spark when cranking the engine. Has enough spark.
I'm thinking there may not be fuel in the tank.
I disconnected the fuel filter under the truck, to check for fuel flow, but nothing came through. It appears the pump maybe dead, considering the truck had been parked up to a year now on my street.
Here are my questions:
%% can I remove the fuel pump without removing the truck bed, if I should just completely remove the fuel tank entirely?
That way, I'd be able to assess what actually is going on with the fuel.
%% each time I try to start the engine using the key, I just get to hear a sort of click kind of noise from the starter motor area as if the starter is faulty. But if I connect a wire to the +ve connector on the automatic starter solenoid to the battery positive terminal, I can crank the engine, but does not start.
Sometimes though, it does as if it wants to start.
Your responses would help me here.
