matt12305
- Nov 8, 2021
- 1
- Washington
- Ranger 2WD 2.9l
I'm having problems with fuel getting to the engine(2.9l v6) on my 1988 ford ranger, I just got the truck a few weeks ago, it has been sitting for 14 years before that. I checked the relays, not sure which one is for the fuel pump but all of them make the click sound so I'm assuming they're fine. I also checked the fuse and it was fine. I then thought of the inertia switch, the windshield had a water leak before I got it fixed, and water could've damaged the switch.. so I bypassed the switch and then I hear a short buzzing (less than a second) under the driver door. this buzzing only happens when I switch from the rear and front fuel tank so I assume this is the fuel selector valve making the noise. so I found one of the problems that for now can be bypassed, but still I don't hear any of the actual fuel pumps buzzing. so I'm guessing they just aren't getting power or even less unlikely all of the pumps are just dead. does anyone have suggestions of what to check next to find the problem?
I appreciate any responses.
