In the engine bay is the Fuel Pump Relay, should be in the engine bay fuse box
The Computer controls this relay..............by grounding its coil
On the main wiring harness from computer to Engine fuse box is the OBD1 plug in, may have a Cap on it with "EEC" embedded
Find it, then look here:
https://www.therangerstation.com/tech_library/OBD_I.shtml
You will see a drawing in above link of OBD1 connector with Fuel Pump slot labelled
That slot is connected to both the computer pin 22(fuel pump control) and the Fuel Pump relay's coil Ground
With Key ON, use a jumper wire from battery negative(or any ground) to that slot
When slot is grounded you should HEAR the fuel pump relay "Click" Closed, and fuel pump should come on
If you don't hear the relay click then relay could be bad
If you do hear it click but no fuel pump then fuel pump Fuse may be bad
You can leave the jumper in place if fuel pump comes on, and start the engine, won't hurt anything, computer grounds that slot/fuel pump relay full time when engine is running
You can also leave it in place, key ON, to test fuel pump wiring back at the tank, see if the 12volts is making to inertia switch and then back to the tank
With key OFF pull out fuel pump relay and test each slot for 12volts, only one should have 12volts with key off, that's from the fuel pump fuse, 20amp in this same fuse box
With key ON a 2nd slot should now have 12volts, that's from EEC relay, this is for the relays coil, needs this so the Ground can activate this relay
