masterbrenden
- Nov 7, 2009
- 1
- Age
- 33
- twin peaks,C.A.
- ford/ford
- Engine Size
- 3.0l v6/4.0l v6
need help
my 98 ranger with the vulcan 3.0 has a lean problem
it is holding presure 68psi idling but is throwing a lean code and is bleeding off to zero in about 1.5 min
the resouce we use at my work (all data) says that 68psi is perfect
i did notice the other day though that the schrader that you check pressure at was leaking, now could that cause a lean code and how tight should it be or were could i get a replacement because i heard the seals are different from normal valves
