Fuel pressure question
Vikz808
7
Hawaii
Ford ranger
So I got a 91 ranger 4.0L, I got into a minor accident the other day which left me with the impact switch going off. I ended up direct wiring the two wires that go to the impact switch to each other, now it sounds like the fuel system doesn’t top itself off and stop. Is that expected after direct wiring the two wires together?
alwaysFlOoReD
5,088
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
MikeG
752
central Texas
B4000
2"
235/75r15
Turn key on but don't start truck. Fuel pump should run for 2 seconds or so and shut off. If it doesn't shut off, then you have a problem with something else.
Vikz808
7
Hawaii
Ford ranger
What could be causing this issue, Tried the fuel relay no luck.
SenorNoob
567
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Do you have water in the area of the computer? Happened to a Sentra my dad had. Got the computer wet and injector and pump stuck on.
Vikz808
7
Hawaii
Ford ranger
Not sure just yet, but passenger side has a leak in the fire wall. Truck won’t stop priming when key is in the on position & won’t start without starting fluid.
SenorNoob
567
Middle Tennessee
245-70-R16
That's weird. Does it stay running if you start it on spray?
Vikz808
7
Hawaii
Ford ranger
Will not start on its own, only if I spray some starting fluid in the throttle body
